Please bear in mind I have never advocated for the use of Reflectix type insulation in terrestrial vehicles, I think closed cell spray foam is a far, far better way to get the job done.
However, the criticisms I have seen made of metalized bubble wrap are not based in physics at all.
The air gap and ventilation requirement are an artifact of the plastic substrate needing to be kept below a certain temperature so it's mechanical characteristics are not degraded by heat on the hot side. Every other layer is cooler and can be spaced from any other layer by just 0.1mm and work fine. They "stack" just fine.
I have ordered 10 temp sensor probes, Pt100 RTD's. I can borrow a set of gear from work which can easily record 16 of these at +/- 0.1degC, I plan on using at least 4 of the probes.
Under a plexiglas cover admitting sunlight, all enclosed in a frame producing the required air gap and providing ventilation for that first layer, I will stack the following from out side to "inside":
plexiglas, air gap, probe, 12"x12" steel sheet (probably 24ga since I can get that easy), probe, 2" deep stack of metallized bubble wrap spaced as minimally as I can arrange for, probe, another metal sheet, and a probe.
Edges of all layers to be taped in such a way convection through the edges of the stack does not occur. I will likely use foam plastic to space the layers, but as that at the edges of the bubble wrap stack will be an inch or two from the edges of the metal sheets, they will not meaningfully bridge to the metal.
The conductivity of steel is well published, and the area is like 144" square.
How much heat is exiting the bottom surface as the top is exposed to the sun and how much is going into/through the top metal is easily calculable, and given the parallelism in construction it should be a representative measure of the effectiveness of such a depth of Reflectix.
Chief likely point of failure I can see is, that first metal layer gets so hot the Reflectix fails. That happens I go back to the drawing board.
