Sorry to post a question that's been beaten to death, but I just want to double check and make sure I don't burn my bus down.
I have a mock up of my first phase of power system for the bus, I figure by skipping the solar and all the roof work involved with it, I can save a bit of money and lots of time and use the bus as a weekend warrior for now, so this is what my initial setup will look like.
Having said that, I just want to make sure my wiring diagram is correct and want some help with sizing the wires, I bought some 2/0 wires based on some previous posts I've been poring through but man are these things expensive and hard to work with, so I want to make sure I'm not doing anything that's overkill and also to ensure I'm not risking the bus burning down.
What would you guys recommend as far as wire sizing goes here? and what about fuses? ANL? or blade? Is there anything I'm overlooking or a way to simplify the system more? 12v distribution panel will be mostly for lights (~8 10W lights so about 1A each, and will eventually have a fan, diesel heater and water pump)
Thanks for all the help as always,
Edit: Oh and as far as wire runs, I'm keeping them as short as possible, everything will be less than 5' in length, I'm going to drill a hole through the battery compartment which is by the rear wheel wells and my power system will be built either under the bed or on top of the wheel well in a shelf, longest run will probably be from the starter batteries to the DC to DC charger and rest will be less than 2' each. Fixtures connecting to the distribution panel will run longer, likely 40' for one of the light, and ~30' for a diesel heater (5kW), assuming the heater to be the highest draw connection to the panel.
