Thank you as well Rusty for the good vibes;
VP44 info
My bus has that pump- it gets a bad rap sometimes, but is a good pump. The important thing to know about it is the fuel cools it, so low fuel pressure will kill it. Install a better lift pump than that crappy carter on the block- probably what your problem is (i hope) as is cheap fix.
I'd put a Raptor or Fass ( i used raptor) pump by the tank. Injection pump wants to see 15-18psi WOT and don't forget, intertia- gas wants to stay in line when you accelerate, lower pressure at pump.
