MountainBiker
My bus has been in storage all winter and it's been a bit of work to get her started again. Well today I tried to move her to a different storage spot and could not. The emergency break seems to be stuck and the lever to disengage it does not work.
She is a '96 Bluebird TC 2000 Cummins 12 v and auto alison transmission. I really had to floor it to just move her a little bit, if it were not for the light being on I would have thought she was stuck in the mud. The emergency break is to the left and is a foot pedal and a hand pull release, I hear something when I pull the release but I don't think it's releasing the emergency break. Also, the regular break makes a buzzing sort of sound if I do not tap it up with my boot after pressing on the break. (not sure if the two are connected)
I'm not mechanically savvy but need to get this figured out on my own and both fast and frugally.
Where is the emergency brake cable and where is it attached to?
How do I know if it is rusted in place?
Can I PB blast it and scrub the rust away or does in need replacing ASAP?
Would AAA be able to do anything to help in this situation as I need to move my bus but if I can't get the break off I can't drive her.
). Then back to forward. Eventually, something goes "pop" rather loudly in the back and I am free. Then I engage and disengage the e-brake over and over, and the regular brakes over and over.
