How do I remove this handle? Thank you!
It's a secret no one has figured out yet. I have no idea what the set screw is for because it sure doesn't make getting the handle off. I gave up.![]()
Sarcasm?
Now I'm curious...
No sarcasm. Normally a roll pin is a removable device where it is pressed into a through hole. I don't believe it's a roll pin, but a set screw, as the hole does not go through. I seriously don't know of anyone who has removed one.
Mine have roll pins and a hole on two sides. I’ve seen some fancy chrome ones in photos on this site. I’d like to replace the plastic with those.
You said the WC handle came off, but not the E door, is there a through hole in the E door handle for a roll pin? Mine was a set screw with an allen.
My emergency door's outer handle had a square shaft welded to it that the inner handle was attached to with a roll pin. Is yours similar? After the handles were removed I plated over the outside hole so nobody could put a square something inside and open the door; I kept the inner handle on a short length of square shaft so I can still open the door in an emergency from the inside.
I also removed the emergency rear window's two outer handles but kept its inner ones, just in case. After a break-in a few years ago I'm now a lot more aware of security weaknesses - I also put a pin through the two sliding halves of my driver's window so it cannot be slid open from outside.
