slager55
I think one of the questions asked is what kind of A/C unit is good top put on a bus1 Can some please address that question too. Thank you
I'm thinking the roof hatch doesn't need a handle on it. Why not remove the knob and seal that hole shut?
The problem is water pools on top of the hatch. If it's raining you can hear the water running off when you open the hatch. Stop the pooling of water on the top of the hatch lid and you'll likely stop the leak. That's what the snow saucer does. You could always put a garbage can lid on top of the hatch. Anything that will stop water from pooling on top of the hatch seems to work.
In my neighborhood it's a three year old blue tarp with strings that blow off in the wind and collect in the neighbors trees. Actually mine doesn't leak anymore. I did step around a drip bucket for the first three months. I still step around that spot by instinct, and look for water but none to date. The water still pools on top of my hatch lid but it doesn't leak in anymore. I'd still like to find a permanent way to keep it from pooling on the top, plus I don't think there needs to be a knob out there for entry. I don't go in that way. I'd still fit but it wouldn't be pretty.
It just seems like a poor design for a hatch to be able to retain water on top of the lid. The ones that leak around the edges just have to be redone the hard way. Take it apart until you can identify the leak, clean it and fix it. Ingenuity counts, but the old fashioned tried and true ways are good too. Nobody wants to be working on it again when it's leaking.
I was thinking seriously about sacrificing an umbrella by cutting the handle off high and anchoring the umbrella, by weights, over the hatch. This is quite a windy area and that sounds like a waste of a good umbrella because about the third time that blew off the roof I would forgo that experiment. You've seen umbrellas turn inside out.
At the risk of making a bad leak worse, I really can't say without being there. I imagine the hatches are pretty much the same. I thought that was absolutely ridiculous to think that my hatch stopped leaking completely by tightening the knob from the outside, but it did. Just turning the knob about three times until it snugged up tight and it stopped leaking. The bucket was still there for another week before I'd believe it, but the bucket was actually dry and it had been raining like mad. I got rain from interior condensation but no leaks that I'm aware of. Lots of condensation around the base the water barrels which seem to loose a lot of heat through contact with the floor. Nice cool drinking water. Have you ever seen water candle in cold weather? I didn't know stuff like that existed. I guess I expected one big ice cube.
The only fix for mine was removal/replacement. YMMV
I tried the tarps. They blew off quicker than the hatches did!
I like the low profile Dometic units. But if you've got the money Carrier are highly regarded.
My hatches were a little leaky when I first bought the bus. But on my first road trip (Colorado to California) they both blew off in the Utah wind outside Moab! And I was headed straight towards a wall of rain... Praying that the storm would stay north of I-70. Lucky for me I avoided an indoor flood, and was able to put together a temporary fix with cardboard, blue tarp, and a ton of duct tape.
Planning to install skylights as a replacement and want to be able to open them up so I can vent from the top, too, both for air circulation in the heat, as well as for cooking. Anyone do any DIY projects that include both a skylight and vent? Or I may go with something pre-fab from a boating or RV parts shop.
Did you ever try the snow sled idea on your bus? I’m trying to decide if that is a feasible replacement for my busted hatch covers.
