CVanDamme
On our 92 TC2000FE our tranny temp guage quit working. Upon further inspection we noticed our wire came off of the sensor. Easy enough fix new end on the wire screw it back down, PRESTO. We then fire it up(engine and tranny both cold, been sitting for hours) the needle PEGS itself in the RED. No big deal sensor is shot, we drive to Tilbury get a new one, drop the fluid, change the screw on filter, replace sensor, top the tranny back up. Everything looks good - except I needed another 1/2 turn on the filter. Fire it up stays in the green, take it for a test drive it slowly comes up with the engine temp, staying 50 deg behind the enginge temp, probably 15 mins into the drive. Everything looks good, pats on our backs all around.
20 min into the drive I look down and its pegged again. Shut the bus off it stays pegged fire it up it stays pegged. Unplug it goes back where it should be. SOOO.... my conclusion is the tranny is NOT that hot, not possible to start boiling 20 mins in on a nice liesurely drive.
More things I noticed or thought of:
- Is there only one wire that goes to the sensor? The loom feels thick, almost like there is 2 wires in there? If so where would the other wire go?
- Would it be possible that the wire is grounding out, do I need to run a new wire?
- Is our gauge itself shot?
ANy and all ideas or help would be great.
Thanks in advance, Chris Van Damme
