adic27
When you guys replaced oil, fuel, etc filters did you go with a certain brand or stick with the brand that was already in used i found Wix branded oil, fuel and coolant filters on Amazon. Is that a recommended or stock brand for the dt466e? Should I stick to whatever brand is already there? I think I remember seeing Wix in there.
Also, are Napa parts usually much more expensive than others? I ask because I was looking for an air filter on Google and the Napa brand was over $100 while others were starting off at like 28 bucks. Whats the typical price for an air filter for an engine like this?
Edit: how about this kit and brand? Found it on Amazon
https://www.amazon.com/International-DT466E-Donaldson-Filter-Lube-Fuel-Air-Coolant/dp/B079J79HVL
