Professor Dred
- Joined
- Mar 24, 2021
- Posts
- 28
I'm looking for some feedback from anyone who either has removed the rear carrier handler and skirt condenser or knows more about this than myself.
I have a 2003 Ford E450 cutaway with a Thomas Built shell and the 7.3L PowerStroke Diesel.
The previous owner had this skoolie built out by a company out west. They removed the handler in the rear of the bus but left the skirt condenser, which I don't blame them. However, I see valuable space under the skirt for storage and/or the mini split condenser which is installed on the rear at the moment and I would like to remove the carrier condenser. I've seen almost all threads here regarding this but not a whole lot of how-to's.
What I know about this so far:
What I'm looking for from you:
Thanks for any input!
- It has 1 compressor for dash and rear AC
- I have to have a shop recover the refrigerant before I do anything
- I need to install the stock condenser in the front engine bay
- I will probably need a new set of manifold hoses
- Which manifold hoses?
- I cannot locate the stock sticker for proper filling weight of both refrigerant and oil, but there is a Carrier sticker under the hood.....BUT, it's completely blank from info. It has all the fields but it's not filled out at all. Does anyone know where to find the stock info for this?
- If I remove the condenser, how am I to know how much oil is in it and how much I need to add back?
- I read somewhere about heater hoses that head to the back. Is that the same as coolant hoses from the radiator? And can/should I get rid of those too, or just cap/recirculate them?
- There's two different-sized radiator looking parts that looks like they sit in front of the stock condenser. I haven't tried to follow the lines to where they lead yet but does anyone know if they are stock? I want to say they might be an after-market transmission and oil cooler but I don't think I'll be that lucky. It's certainly not the evaporator for the AC system because I know where that is already.
