SweetNobodies323
Hey everyone, looking for some help here. I am taking a L for learning as I have made a mistake.
I was removing my AC units which I have done successfully except I removed the air compressor and realized that the belt was connected to the engine and seems to have been a key component of making the bus start. I have the compressor removed and am considering either putting it back in and capping the tube holes properly or installing an idler to the bracket that was holding the compressor to replace it and replacing the belt for a shorter belt.
Either way I see I have made a painstakingly amount of work for myself but you live and you learn. From what I understand in order to remedy this issue, I will need to open the front of the bus to remove the radiator section that is in front of the engine fan, remove the fan and put the belt back on. This requiring to drain some coolant in order to detach that front part. It did kinda seem that I could unbolt the radiator screen in front and that was actually not attached to the tank but i will find out for sure when I go to work on it.
If anyone has any insight I will gladly appreciate it as I've seen some post but not really seeing a clear cut answer as everyone has different a/c air compressor situations. I am also curious as to why you're able to take some out and it not effect anything and why this one is different.
If I do keep the compressor does anyone know how to close off the hoses?
