TygerCub
- Joined
- May 7, 2009
- Posts
- 784
For those of you who built your floor by just laying (or floating) it over the surface without fastening it directly to the metal, how is that working over the long term?
Everyone who has been asked has said the one thing they would do different is add more insulation 8) . With that in mind, I am putting 2 inches of foam on the floor (I'm only 5'4" and it's a 6'6" bus
). Today I am picking up the vapor barrier (probably roofing felt), the 2" foamular sheets will be ready for pickup on Tuesday, and the 1/2" plywood I can get anytime. My final flooring with either be the recycled bamboo (if I can clean the mold from the bottom), or a thin laminate. Total space taken will be about 3", depending on the final thickness of the top layer.
But with that much thickness, it seems to me it would be difficult to screw things securely to the floor, so I plan on attaching most items directly to the walls. That, however, brings back questions of squeaking while driving.
Since most items like the cabinets, closets and countertops are going to be no wider than 24", should I frame out that 24" area and sink the foam and flooring between the framing? That would give a more stable surface for the interior build, but would also create a thermal bridge that the foam is supposed to eliminate. I feel like I'm over-thinking this, but I really don't want to find myself saying, "I wish I had done this" later while traveling down the road. :?
- Does it squeak at all while driving? [/*:m:1gpm2zcg]
- Or make crinkle sounds while walking across it?[/*:m:1gpm2zcg]
- Did you attach your interior structures to it, or just to the wall?[/*:m:1gpm2zcg]
