steveoutdoorrec
- Joined
- Apr 18, 2015
- Posts
- 23
I'm working on converting a 1999 Blue Bird that was an accessible bus. It has a wheelchair lift and no wheel wells to deal with, gotta like that.
The downside is that as an accessible bus all of the seats could be adjusted. There are four aluminium tracks down each side of the aisle for the seats to be attached to. These tracks are attached every 4" with a stainless steel bolts. Works out to over 1200 bolts to remove.
I can't get to the nuts on the bottom for most of them so there is no way to put a wrench on them. I've tried using an allen wrench to remove them and only got one to move. Tried a allen bit on my impact driver and only got one a little out before the nut spun. Other methods that I didn't have luck with were a cutting wheel on an angle grinder, a reciprocating saw (wood blade can't cut through to the metal and metal blade won't do wood). Last try was with a die grinder with a carbide bit but my air compressor won't keep up.
I haven't tried a drill yet because 1200 bolts and there must be a faster way.
Anybody else run into this problem? How did you remove them
