MadCompSci
I have a 2004 Thomas 72 passenger flat-nose, front-engine bus. I was going to install some fairly heavy items under the bus - 8' cargo box (500 pounds or more when loaded?), the generator (150 pounds including mounting frame), 175 gallons of fresh water (1600 pounds including container and frame). So about 2500 pounds total. I will attach to the frame whenever I can, but I would also need to hang some of the weight from the "T" supports that the floor rests on. Most of the weight of the roof and side walls are also supported by these cross supports. I estimate that the weight of the seats & passengers would be about the same load as the weight of my interior build-out.
Is this too much weight to hang on these cross "T" supports?
