inhof009
I'm still looking around at buses, but in the mean time I have been pondering some flooring. Since I intend to heat by radiant, it is pertinent to the floors. My wife and I intend to make this build primarily RV, which means any A/C will run off of shore power. However, I am planning a trip up to MN around Christmas time for me and the dogs, involving driving during the day and sleeping at a truck stop or other at night, so we would need to heat while stationary.
With that in mind, I've been considering running a water heater from LP and pumping the hot water along my floor via 12v DC pump from batteries that will charge during the day while I drive (isolator). A basic pump should use about 8 amps, which I can round up to 100 for a full night's sleep with some wiggle room (10 hours). 2x 6v in series with at least 200AH should be enough to keep me running on this trip.
Now come the questions. For my floor, I have approximated about 1" of "stuff", which includes insulation and plywood, then carpet on top. I don't want to run the hot water under the plywood, so can I get away with foregoing the plywood and using 1" rigid foam board and a router to make the lines run, then carpet on top?
As for the hot water setup, can this be a closed system, with an LP tankless water heater and a pump on the hot side, with return from the floor to the cold side, or would I need to build in air eliminators and expansion tanks? How efficient would that be, and how long would the propane last with constant flow?
Long term plan is raise the roof and go crazy with insulation to reduce HVAC requirements, but that will be later down the line when I have a better space to work in and more money to play with.
Edit: Another idea I had was to use a small volume tank propane water heater, have a potable water tank with a pump to the water heater, and another pump from the heater to the floor, and the floor would return in to the water heater.
