captainkf
Well, I am now going back and redoing the bus. I have decided I need far more insulation. So, here's my question.
I am going to place foil insulation under laminate or lino. So I need to lift up the stock rubber and possibly wood. Height is a concern since I am a bit over 6'2" so I would like to reduce how many layers I use. What if I were to remove all the material right down to the metal, fill holes, lay plastic, insulate and lay flooring? And not lay wood down?
I look forward to hearing from you all! Thanks in advance. -Richard
