cofrari
I know there are plenty of other threads about flooring, but they also seemed pretty old.
The recommendations I read were to use Marine Quality Plywood and Foam board. Can people confirm if these are the proper kind of products that are being referenced:
Marine Grade Plywood:
https://www.lowes.com/pd/3-4-CAT-PS...-Sanded-Plywood-Application-as-4-x-8/50254845
(is $76 a sheet about the price I should expect to pay)
EPS Foamboard:
https://www.homedepot.com/p/R-Tech-1-in-x-4-ft-x-8-ft-R-3-85-Insulating-Sheathing-320821/202532854
So my assumption is to clean/sand any rust of the metal bus flooring, apply a rust-preventive primer (Kilz, Rust-oleoum, etc), lay down the foam board, and then lay down the plywood on top of the foam board. Does this sound correct? Any other suggestions?
EPS Foamboard:
