Maggie01
What is everyone using for flooring in their skoolies. We've taken the floor up, ground and treated rust, painted the floor with Rustoleum, put 1x4's all around the edges, glued down 1" insulation, taped the seams, and topped all that with 3/4" tongue and groove plywood (with the insulation going crosswise and the plywood going lengthwise). However we can't decide on the top floor. I was going to just use a torch to burn the plywood and then put multiple coats of floor poly on top, but I forgot that none of the seams would match (we purposely offset them), so that wouldn't look good. Thought about laminate planks, but am afraid they'd warp with temperature/humidity changes in the bus, plus we have a large white german shepherd whose nails could do some damage to floors. Thought about getting some 1/4" plywood, cutting it into 5"×48" planks, staining (or torching) them, gluing/nailing them to the 3/4" tongue and groove plywood, then coating them with lots of floor grade poly. We would also coat the tongue and groove plywood underneath with a couple coats floor polyurethane too. Not sure if that'd work either though. What does everyone use for their floors? And how are they holding up if you have pets?
Also are you putting the flooring down over the entire floor, then putting furniture and walls over it or are you building everything out, then putting your flooring just down the middle where it shows?
