dbsoundman
Hi all, my wife and I were discussing the steps leading to finally putting some foam and plywood down on our metal floor last night, and she mentioned she had concerns about one piece of the metal flooring between the two rear wheel wells which has a "hump" to it. To be clear, this is a Thomas bus, and the metal floor is made up of about 6" wide "planks" that go across the bus from side to side. One of these planks has a 1" or less hump to it, which is definitely noticeable but I didn't think it would be problematic. However, since we're planning to use PL Premium to glue down 3/4" XPS, then put 1/2" or 3/4" plywood (likely tongue and groove) over the metal, I wanted to make sure we wouldn't end up with a major bump in the floor there. My hope is that the foam would compress a bit to compensate for the hump.
Any thoughts? I can't be the only person that has an uneven metal floor...
