Frankie_Mermaid_00
- Joined
- Dec 18, 2022
- Posts
- 6
Hello,
This bus conversion is being sold AS IS. Near Atlanta, GA. I have noted several items/materials that will be included with the bus throughout this description for you to install if desired. The conversion is nearly complete, and will just take a little work adding your own finishing touches. I am selling it for $25,000. Please PM me if interested.
T444E Diesel Engine – cranks up and runs like a champ.
• 3,890 miles on Current Odometer reading – Found an old bus log with 197,000 miles listed while demolishing the interior space, exact miles unknown but likely a little over 200,000. This engine can run over 500,000mi. with ease if cared for.
• Block Heater Port in place for connection
Allison Transmission AT545
Exterior Bus length (Bumper to Bumper) = 28ft.
Interior Living Space = 20ft. long by 7ft. 5in. wide
Ceiling Height = 72in. (with included flooring, 7111/16in.)
2” Closed Cell Spray Foam Insulation throughout the entire bus
R5 Rigid Foam Board Insulation in the floor
Sheet Metal Window Deletes
All remaining windows were removed, cleaned, and resealed during installation
Roof Deck spans entire length of the bus roof
• Solar panels were going to be installed on the front section of the deck. *Up to 6 Renogy – 100W 12V Monocrystalline Solar Panels (with Mounting Z Brackets) can be included at additional cost to the sale. These panels have never been used. $80 per panel and bracket or $450 for all 6.
• 10AWG Solar Wiring and roof gland are already installed for you to connect the panels to a solar charge controller (not included).
Aluminum ladder for roof access
2 – 12V RV Roof Fan Vents
Black Steel Underbody Truck Box – 14”x16”x30”
Quick Connect Air Line
5 gal Auxiliary Aluminum Gas Tank
• For interior diesel heater. *Line needs to be reconnected to filter
12.2 gal Horizontal RV Propane Tank *Hoses needed to connect interior appliances
40 gal Grey water tank
• Level sensor with interior gauge
• 15ft. RV sewer hose kit included
30 Amp Shore Power Connection (25ft 30Amp Power Cord and 15Amp to 30Amp adapter included)
Instant Propane Water Heater
• Fogatti InstaShower 8 Plus, 55,000 BTU RV Tank less Water Heater
City Water Fill Cap
• RV water pressure regulator valve included
Side and Rear View Cameras
Custom made front door with repurposed sheet metal from the bus.
• RV Window with screen
Passenger Jump Seat
22,000 BTU Floor Heater/Defroster
• Need to connect to 12V power and switch
Truck Air Horn
3 Speed 12V Fan
Back Up Camera Monitor
12V Indicator and USB/Cigarette chargers
Overhead cabinets for additional storage
Red Oak Laminate Flooring Included (*not installed)
4ft. wide couch
• Pulls out into a chase for a total length of 4ft.
• Hinges and locks up for electrical access
Side door for great views from the couch
Structure in place to add a bar-style “dinette”
Electrical System (All Victron Energy Components, excluding batteries)
600Ah Battery Bank (Li Time)
• 6 – 100Ah LiFePO4 wired in 3 parallel pairs and then into a bus bar
• 200Amp Mega fuse for each battery pair
• SmartShunt
• Battery disconnect switch
• 400Amp Mega Fuse for main system
Victron Lynx Distributor
2 - 12V DC Fuse Panels
• Both with 100Amp fuses
120V AC Distribution Panel
• 6 Outlets
• Kitchen outlet is GFCI protected
Victron MultiPlus-II 12/3000/120-50 120V
System is ground to bus chassis with 4/0 Cable
Victron Cerbo GX
• GX Touch 50
(Included but not installed yet) Victron Orion Tr-Smart 12V-12V | 30A Isolated DC-DC Charger
• And all wiring components needed for install
10AWG Solar Wiring and roof gland are already installed for you to connect the panels (optional included for additional cost) to a solar charge controller (not included).
Custom Laminate Kitchen Countertop
• 541/2in. long counter
• 761/4in. total length of kitchen
• Pop up Outlet – 3 GFCI plugs and 2 USB chargers
181/2in. by 16in. sink with a 9in. depth
Soap dispenser
Stainless Steel Faucet with pull down sprayer and pot filler handle
• Control the water flow with on/off push handle
Stainless Steel cabinet and drawer handles
Soft Close Drawer Slides
Fridge space
• 24in. wide by 61in. height
• Option for an AC or DC Fridge
GE Profile 17in. Gas Range (*Needs connection to Propane)
• 3 burner stove top
Kitchen wall contains the fresh and grey tank level indicator dials on switches, water pump switch, LED touch dimmer switch, and water heater control panel
*Paint can be included for kitchen cabinets and drawers. They are primed already and just need color.
Desk
• Hinges up for desk storage
• Extends out for a total length of 351/2in. (depth 24in.)
Touch LED Dimmer Switches
Diesel Heater underneath desk seat
• Remote Control and monitor included
Closet Space
• 231/2in. wide by 61in. tall
Bathroom
• 371/2in. wide by 381/2in. deep
• Fully waterproofed with Red Guard, Hydro Ban, and shower pan liner
• Tile included along with thin-set and grout (*not installed)
Custom Nautilus Shower Door Included (*not installed)
• 67in. height by 48in. width
• Black frame and Opaque Stripe screen type
Shower head and SharkBite adapter included (*not installed)
Custom Compost Toilet
• Slides out on locking 500lb drawer slides and tucks away for more shower space
• Toilet compartment is air sealed to help reduce any potential smell
• 12V Fan for ventilation (on a switch)
• Toilet seat hinges up for easy maintenance
• Urine Diverter (*not currently attached to any holding tank)
Full XL Bed frame (*no mattress)
Built in Hamper
Built in storage compartment at the head/foot of the bed frame
4 Drawers underneath Bed Frame
• 2 – 251/2in. long by 173/4in. wide drawers
• 2 – 22in. long by 163/4in. wide drawers
55 Gal Fresh Water Tank
• Level Indicator
• Drain line
• SEAFLO 42 Series 12V 3.0 GPM 55PSI Continuous Duty Diaphragm Pump with Bypass for Reduced Cycling
• SEAFLO Accumulator Tank Water Pump Flow Control with Internal Bladder - 125 PSI, 23.5 oz (0.75 L)
Both city water and tank water run through a GoBluTech Trio Filter System with 0.2 Micron filter
Pex Pipes throughout with SharkBite connectors
Additional Items Included Otherwise not specified
• 12V Reading light
• Wheel chocks
• RV leveling Blocks
• Exterior Bus Paint for needed touch ups
• All the keys needed for operating the bus
• Clean Title
City Water Fill Cap
Passenger Jump Seat
Truck Air Horn
3 Speed 12V Fan
4ft. wide couch
• SmartShunt
• 6 Outlets
Victron Cerbo GX
• GX Touch 50
Soap dispenser
Fridge space
Desk
Closet Space
Bathroom
Built in Hamper
• Level Indicator
• Drain line
• 12V Reading light
• Wheel chocks
• Clean Title
