Ford b700 trying to reach highway speed
Steventhomas1980
May 21, 2020
6
Hello everybody I’m new to the group and have just purchased a 1991 blue bird school bus b700 with a ford 6.6 diesel.. I’m having troubles getting it to go over 45 I’m told to remove the governor any idea how I go about that?? Any help is much appreciated
Is it a NC bus?
What rpm is the engine spinning at top speed?
YOu probably have really low gearing.
I’m not sure I don’t beleive my bus has a rom gauge.. but at 45 it’s revved really high.. I’m not sure if my transmission just isn’t shifting into the next or what the problem is
What rear end would I need? Or can I just change the gears is it? Would this be an expensive change?
engine speed at 60mph
so, I figure about 517 tire revolutions per mile..... 6.83 rear end gear means at 60 mph IF you have one to one drive in high gear. then that means you spin the engine at 3,530 rpm......... or 58.85 revolutions per mile an hour.... that is a bunch for most diesel engines....... so lets see what a 5.38 rear gear will do....... at 60 mph with direct drive I have figured about 2,780rpm.... bout the upper limit and maybe even stretching it a little...
4.88 will put you at 2,500 rpm at 60 mph with a 9r20 assuming a 9r20 new is around 40" diameter and my math putting that tire at 517 revolutions per mile.
If my math is correct you are at around 2700 rpm at 45mph right now... so, if the motor can pull it on flat land with small head wind... then a 4.88 gear will give the about the same rpm at 60 mph
william
found a 5.86
place in freehold new jersey........ that is the tallest ratio I have found so far.. Might have to buy entire axle.... might be cheaper to find scrap yard parting out busses and replace entire rear end..... I expect up to $1200 for entire rear end assembly..
william
just starting
first look seems to indicate ratios 3.73 4.11 4.56 4.88 5.29 5.38 5.83 5.86
other gears shorter, but I dont think they are of interest to you
at least they made them... looks like three different gear carriers so you cant just buy ring and pinion.... have to stay within the range..
william
To find out what your trans is look on the side of the trans just above the oil pan on the passenger side and there is a data tag with the model no. on it
