Papabear-SKO
Ice Czar said:Smitty said:the typical crackhead
typical crackheads dont run labs in the middle of no where either![]()
Typical crackhead/methers don't run labs. Its the manufacturer/dealer/user,that you will find in remote locations. I have been on different remote "Bakery" arrests and they always amaze.
*Camp trailers set up to cook on a National park/lake
*Pick-up with a tent cooking on the prarie
*A remote ranch house with no winter access (had to use our 10 passenger snow coach to get there)
*motorhome parked at the KOA
These people have ALL BEEN ARMED with everything from a .22 to H&k battle rifle. The best thing to do is be aware of what's around you. If your just driving by, you will just pass unscathed. Trust your gut on a situation that dosent feel right.
Armoring a bus would be a costly and weighty situation to stop anything bigger that a .22 or average handgun. A standard .223 ball round will go through most vehicles. A .308 ball round will slice through 1/4 steel and still fragment inside. There have been talks and tests done on a lot of different materials to bulletproof. One that suprized me was using thick phone books. Another was building a sub-wall with 2x4 studs, covered with 1/2" plywood and filled with 3/4" gravel. That would add bullet deflection and fragmentation.
Weapons?
A handgun 9mm or bigger. Auto or revolver. Note: a revolver will never jamb and you'll never leave brass laying around. If your a good shot, you don't need high capacity.
A pump shotgun. Remington 870, Winchester defender, Mossberg 500, all good choices.
A rifle. .223 or .308 bolt gun or semi-auto. The russian caliber in the SKS's and AK's is another choice. And you can reach out and touch someone.
The rugar 10-22 is a great all around rifle but has it's limitations. You'll get no respect from a junkie who's popping caps at you, if you return fire with the pop of a .22 Now open up with the roar of a semi .308 and they will go home.
Your best defense is on top of your shoulders. Stay clear of situations you are weary of. Always provide a way out. Actually, as Ice Czar said,I have thought of a trap door just behind the axles in my bus. Escape route, as it were. You could leave, let them go in to plunder and just pick them off as they leave. 8)
