bus-bro
I'd route the drains under the rails into the low side of the tank. Plumb in a clean out. That going up & over the rail just feels like bad ju-ju.
There is usually a maximum allowable vertical drop from the fixture outlet to the water seal. Why you ask? Because the further the liquid waste drops the greater the velocity of the water. The greater the velocity of the water rushing through the fixture drain the more likely the drain will siphon the trap seal. The vertical drop for sinks, lavatories, showers and bathtubs is between 18” and 24” but not more than 24”. The shorter the vertical distance the more efficient the trap functions.
