golfersmurf57
- Joined
- Sep 30, 2017
- Posts
- 386
I'm in the brain fart stage of my conversion right now so nobody kick up there legs and cackle at the posts I do.
First- what kind of shore water fitting will I need to fill the tank ?
Second - I will be running water pump off the coach dc system. Any recommendations regarding type?
Third I'd like to bring my shore water in below the water pump and check it off so it doesn't spin the pump backwards and overflow the water tank. I'm thinking a tee in the inlet line with a check valve for tank fill versus shore and also to check off pumped water against fill receptacle and a third to check off shore water from the pump. Does this sound like enough or am I missing something? I will be filtering the water before it enters any components.
Fourth - is there a reliable float valve for tank fill?
Ok you can stop cackling and shoot me some recommendations!
Thanks guys.
Thanks guys.
