It makes no sense to have the tech screws threading into the wood. All that is going to do is cause the wood to lift as the screw tip hits the metal. Even if the screw does finally penetrate the metal there will still be space between the wood and metal and the wood will seem lose even with the screw head flush with the wood. To then get the wood tight will require the screw to strip out the threads in the wood so the screw can finally pull the wood to the metal. A hammer drill may help with this but since there is way more thread contact with the wood, either the screw threads themselves where they go through the metal or the metal itself are very likely to strip.
Drill a pilot hole of the proper size for the tech screw through both the wood and the metal and then enlarge the hole in the wood to a size that lets the tech screw drop freely to the metal through the wood. When actually tapping the metal with the tech screw use a drill speed just fast enough to allow for the tech screw to cut. Too fast a speed will suddenly bottom out the screw and either strip it or break off the head.
