Yep. The water seperator filter was empty when removed. Looks like rust in them. Not good. Where is the transfer pump? I am super green with this bus��
Ok. I found the transfer pump. Do I have be concerned with high pressures or anything other than changing out this pump?? I see a kit with O rings and such.
How long was the bus sitting before you bought it?
Do you have more than a ¼ tank of fuel?
Open the drain plug on the bottom of the tank -- I let about 4gal flush out of mine to ensure any water and dirt on the bottom of the tank came out.
Pour some of that fuel in a glass jar and let it settle -- then gently swirl it. I could easily see water droplets drifting around when I did this with mine.
If the fuel coming out doesn't look and smell like fuel, drain it out till it does...
I'd refill both filters and BE PATIENT this time after you start it. Just let it run at high idle for ten minutes or so BEFORE trying to put it in gear. Give it time to pull a solid stream of fuel from the tank to the engine before you put the demand of open throttle on it.
The tech at my local Freightliner dealer said it usually took an hour to reprime one of these engines after a filter change -- priming the pump and blipping the starter motor for 20 seconds... CAT says not to pre-fill the filter... CAT is more concerned with getting contamination in the filter (from pre-filling) than how long it takes you to prime...
By pre-filling my filter my 3126 started in seconds -- too easy.
I stroked my primer hundreds of times and never felt any resistance -- I suspect they air/vapor lock. Maybe you're supposed to crack open the fuel fitting downstream of the primer pump?
