musigenesis
My fuel tank (and the frame supporting it) and the floor above are fairly rusted like the rest of my floor. Naturally, I can't access the underside of the floor in this area from outside because the tank is in the way.
I don't want to do anything as drastic as cutting the entire floor out above the tank, but what I am considering is cutting out the 8" or so flat strips of floor between each crossmember on the underside. Here's a pic of where I want to cut the floor:
With these openings cut out, I could access everywhere on the underside here and ospho and paint it and also deal with the top of the fuel tank itself. Then I would screw/bolt/plugweld a single large patch down over these openings (apparently there are weld-through seam sealers that I could use here, which I have to experiment with).
Is there an easier way to deal with this problem? How difficult is it to drop the fuel tank temporarily to allow easy access to the underside? I'd rather not cut these additional holes in the floor if I don't have to.
Is there anything to worry about during the demo as far as the fuel tank itself is concerned? Like, any wires or something I'm likely to cut through?
