Why should you use BLT Roll-Out Garage Flooring instead of epoxy coatings?
1) Easier Installation:
The preparation for painting an epoxy-coated concrete floor can be intensive- potentially lasting a period of days. Even then, there is no guarantee the coating will stick. Painting a garage floor involves many variables such as prep-time, humidity, temperature, dry-time, and the skill to do it. Yes, there are so called "Do-It-Yourself" Epoxy kits. However, properly painting a concrete floor requires skill that does not come in a kit. And even if one has the skill, the numerous steps required for a quality garage flooring paint job such as degreasing, etching, taping, drying and etc. make painting a basement or garage floor less than practical. With BLT Roll-Out Garage Flooring®, simply unroll onto the garage floor and trim the edges with a utility knife.
2) Lower Cost:
A quality professional coating company will likely charge anywhere from $5 to $15 a square foot in labor fees alone. Snap-together floor tile solutions will cost $4 to $6 per square foot for the tiles alone—plus hourly labor charges for proper installation. With BLT Roll-Out Garage Flooring®, material costs will be lower and labor costs will be eliminated.
3) Longer-term Durability:
Once painted or tiled, these concrete garage flooring solutions are subject to chipping, peeling, cracking, scratches and hot-tire pickup. These normal "wear and tear" realities can lead to the reapplication of the paint or tile within a matter of years. BLT Roll-Out Garage Flooring has been manufactured from tough, specially formulated, polyvinyl material that will beautify in minutes and last for years.
Traditional flooring installation on garages and commercial spaces is time consuming, stressful, and expensive. Additionally, all of the labor that goes into the application of these floors can be easily negated with a damaged, sub-par flooring material. There is no floor as strong or as easy to install as G-Floor's Commercial and Garage flooring. It installs instantly and with limited "heavy-lifting" involved and will last for years after competing garage and commercial floorings expire or are damaged.
