porkchopsandwiches
I took the rubber heater hoses out and shortsightedly threw them out while I was demoing the bus late last year. They were run inside the bus, on the floor. I want to run them underneath, could I use 1" galvanized pipe as a supply and return run underneath and then just rubber hose to connect to the heater core / block? Would this cause corrosion issues? I want to use metal because being under the bus it seems like it would be more durable than a dangling rubber hose. If the galvanization could be an issue (not sure if the inside of the pipes are galv or not) I could just use black painted natural gas line, which is just painted steel.
Thanks
JB
Thanks
JB
