Gathering the materials for the build...
dbhost
Oct 31, 2015
720
League City, Texas
Okay so the plan at this point is...
#1. Hard to describe, but I am looking for a short / medium bus. Either on the smallest side a cutaway 5 row, on the longest side an FC 8 row. That should keep me under 30'. I have picked 30' as the target honestly for driveability / parks access concerns... Not to mention storage. It should be noted, I am NOT planning on full timing, at least not in my first build.
#2. I have much, but not all of the materials needed, and of course the size of bus will impact this, but so far I have...
  • Tongue and Groove Bead Board. 1/4" thick 6" wide and about 100 linear feet
  • 8 4x8 sheets of 1/2" cabinet grade plywood
  • 20 Southern Yellow pine 2x4s
  • 12 R-Max foam board sheets 4x8.
  • Coleman 2 burner camp stove
  • Coleman Camp Stove Oven.
  • 5 Cu Ft low draw B&D 110V fridge.
  • Mr. Heater Portable Buddy heater
  • 1/2" black iron pipe
  • 1/2" PVC, and CPVC pipe / fittings galore.
  • 2 recent 2 lb propane tanks, (2017)
  • Zodi instant hot shower propane,
  • 4 @ 7 gallon aqua tainers
  • Unused single bowl kitchen sink, stainless
  • Unused king memory foam mattress
  • Row of used / pull out plywood cabinets. Not MDF. These came out of a neighbors house during a remodel a few years ago...
  • 100 bd/ft of 4/4 pecan, maple, walnut, and red oak lumber.
  • Unused (new in box) Glacier Bay pull down sprayer kitchen faucet.
  • Box of electrical outlets, switch plates, switches etc... Need boxes and wire.
  • Pull out 60 amp Square D breaker box, and breakers. 60 amp main, 4 @ 15 amp branch circuits, ground block etc...
  • 8K BTU Window Unit A/C. 110V lightly used.
To at least the Zodi, I am seriously considering upgrading to an Ecotemp. I didn't know about the Ecotemp when I got the Zodi (the company was almost brand new then...), and I am REALLY liking the L5. I can plumb that into the bus. Main issue will be venting, which can be done with a roof jack.
I am not sure about flooring, toilet, shower fixtures / how to accomplish that is going to depend on the end size of the bus we get...
I am not married to having a sofa or dinette, would prefer swiveling captains chairs and TV trays... (I'm big and need the room). So I will be scouring the wrecking yards for some pull out swiveling captains chairs from a conversion van.
I am pretty sure I am going to want to sheet metal over the windows, and swap in some more energy efficient, probably tinted windows, and at least one, more than likely 2 Fantastic Fans.
What else do I need to get the build done?
So a couple of items I am considering, and have mentioned in the plumbing section...
#1. I have little to no interest in a permanent mount toilet as I am not planning on going full time. However if that changes, I will want a proper toilet / bathroom. Should I just bite the bullet and plan for a full bathroom per se. If I do it will likely be a wet bath of some sort to conserve space. A big one, but a wet bath none the less... I should also note, I have no qualms whatsoever doing fiberglassing.... It's really not that hard to do...
#2. The more I think about it, I have loved having the Zodi, but the in / outlets on it are tiny 3/8", and the pump isn't exactly high flow. It takes 20 minutes or more to empty out a 4 gallon container, so flow is about 1/5 gallon / min.
#3. I haven't given much though to gray water storage, and swapping between 7 gallon aquatainers works, but not ideal...
