General Steel/ Sheet Metal Questions - Roof Raise
ChrisLifts
Dec 17, 2021
40
Hey everyone,
A few questions below that I can't really nail a concrete answer for. I know this probably varies from bus brands.
2004 International CE200
1. What type and gauge of steel is recommended for the square tubing that will be welded in the window hat channels for a roof raise? The available tubing at my local hardware store is 18 gauge hot rolled low carbon steel. How much overlap would be recommended on the top and bottom half of the hat channel? Looking at a 12" roof raise. Would 2' length 1" diameter steel square tubing be sufficient? That would give me a 6" overlap on the top half and bottom half of the hat channel that would be welded for support.
2. When fabricating the roof raise brackets, I know there are so many options out there and I can't be bothered to pay a fortune for prefab ones, I was thinking about getting some 4inch steel door hinges and knocking the pins out to separate into two pieces. Then, welding a piece of steel tubing on the inside portion of the hinge and then welding that to the bus frame. Thoughts on that?
3. For the welds, will a 120v 20amp basic wire-fed Flux Core welder be sufficient? I'm not super familiar with welding so I wasn't sure if the little wire that I'm assuming is melted and hardened to fill the gap (complete the weld) would support the weight of the roof. My fear is having a solid weld around the brackets and then they just snap off because the bead wasn't with a particular type of material and just isn't bonded well. Like using elmers glue versus gorilla glue. They both stick but one is obviously much stronger. Or the welded-in supports in the hat channels breaking from the weight of the roof or moving the bus. Just want to be on the safe side.
4. Once the roof is raised, I will obviously need to wrap the bus in sheet metal. What gauge of sheet is recommended? I don't want something flimsy of course but want to avoid something so thick and heavy it's overkill.
Maybe I could find the answers to what type of OEM steel was used in the bus in a manual somewhere. Posting here because I know a lot of you are very knowledgeable on these topics and would probably save me hours of already confusing research.
Thank you,
Chris
Hey everyone,
I would think at least 6" overlap for 12" raise is sufficient. Contact a local metal supplier and you will be better pricing than HomeDepot. you can order you skin Sheet metal at this time too. I would suggest this however. Pull two windows out of the bus and cut a 6" sample section and take that to a metal fabricator and ask them to make a custom hat channel that nest around correctly.---See if one of the shop guys will do it as side work.--- I had like 36 pc at 36" fabbed for a couple hundred bucks. You can weld the perimeter seems and also throw 3 plug welds in each overlap section.
That may work..... My $0.02... Bolt with grade 8 bolts rather than weld the brackets on... WAYYYY easier to remove afterwards. Pro of the hinge plate--- it has pre drilled holes... Con--- the holes are prolly only 1/4, id use 3/8 bolts at least. and the metal is prolly thinner than I would feel comfortable. Try looking for 3/16 or 7/32 plate from the home depot for this.
Flux core is fine, Its what i used... You'll end up welding allsorts of kind of dirty, awkward, rusty, painted surface through the conversion so just stick with flux... Chances are you ribs are galvanized. Do some reading on galv welding and zinc posing. I got myself sick twice while doing my raise. Its not a death sentence but it kind of sucks for a day or two.... i used a hobart 140amp 120v welder. Max my machine will weld is 3/16 to 1/4" plate. I Dont think i had it maxed out when i was doing the raise at any point. I would try your welder to build the roof raise mechanisms first, you plate bracket and carrier tube will be a similar thickness to the rib extension pieces.
Just use 12-16ga cold rolled sheet steel. I think i used 14g. 12 is prolly overkill. 16ga or less can give you oil-canning or kinks when you install or if you plan to install spray foam. ---See Transcendence Existence for the slight pillowing that happened to his skins after he spray foamed---You could spend the extra on galvanized but why??? When you get the sheets delivered. Immediately clean the oil off, and roll two coats of enamel primer on them. The brown rustoleum primer you prolly used to condition the interior floor pan is fine. now they are protected and ready for whenever you need them.
Thank you,
Chris
You can check out my raise on here or Instagram/Facebook. @5speedhouse. Shoot me a PM and I can talk you ear off. I can video call you if you want to see some things this weekend.
This is all super helpful information I really appreciate it!! Looking into local suppliers now.
I'm not super-familiar with welding either, which is why I'm limiting my practice to things that won't result in catastrophe if the welds were to let go. I can't even imagine attempting to weld up a roof raise not knowing what I was doing. Nobody can tell you what to use or how to use it to successfully create structural welds on a moving vehicle. It's a matter of knoweldge and substantial experience, which you admittedly don't have. I'd think this is one of those things you'd really want to find an experience, accomplished welder to help you with. The result would be much safer, and you'd likely learn a lot in the process.
depending on where you live?
a member here either had some left over or was offering to make hat channel.
he lives/lived in georgia.
maybe pm
01marc
I found a local retired guy who has 50 years welding experience. Charging me only $50 an hour. Fabricated my brackets and already welded them on. Waiting on steel tubing to come in since suppliers are behind and then he's going to assist me raising the roof and welding in the new tubes. Here is a closeup of the bracket system we have.
6" flat angle steel rectangles
6" steel 1" rounded tubing
7/8" hardened solid steel all thread rod
7/8" hex nuts
7/8" washer
Guy used a massive MIG welder and had all the brackets up in 20 minutes.
I’ve heard people that used 18 gauge wished that they’d had used 16 gauge,they say 18 gauge ripples as thier driving down the highway... I’m trying to learn from others mistakes so I don’t make the same...cheers
No that's not true. not at all.
Buses are BUILT from 18ga. IC uses 16ga on some roofs but by and large they're 18 from the factory.
20 will even work.
I've used 16 to skin over some roof exits and its a lot harder to cut and work with than the 18.
That’s fine! I’ll be using 16 gauge with a fourth rub rail from half way to the back of my bus just for looks...cheers
Oh..I have plasma cutter/fabshop at my work which will allow for creativity
Okay everyone so the roof raise is complete. It was finished over a week ago but bad weather rolled in so I didn't have much of a chance to take photos. I had to dig about 12 inches of snow out of the bus LOL.
The details.
After cutting the bus in half and it being suspended by the 4 brackets, we attempted the car jack/ lifting method to raise the roof. IT TOOK FOREVER. So between myself and the guy welding (65+ year retired guy) we just wedged our shoulders under the top of the window and gave it big shoves raising it a couple inches at a time in each corner. It wasn't so bad and went SO MUCH FASTER than using a jack.
2' lengths of 1 1/4" steel tube was welded inbetween the 1' raise giving a 6" weldable portion on the top and bottom hat channels.
Here is the finished product with snow still inside.
How thick was the metal that was welded in? Would you be able to take a few closeup pictures of one of them where the bus channel meets the welded in portion? Thanks in advance. I'm probably going to do at least a partial roof raise on whatever bus I eventually wind up with, but will be buying a welder in the next few weeks and want to make sure whatever I get will be up to the task.
Wrapped up my roof raise a month ago.
What I went with 1” tubing 1/8th wall. I overlappedas much as I could top and bottom. I pressed a 1/8 flat stock bar in with the square tube to ensure I had a tight fit and seam welded my heart out. Also plug welded the back of each channel a couple times for good measure.
I used a Lincoln 140 weldpak and .035 wire for 90% of it and I wished I’d gone with .030 instead, would have had cleaner welds.
All my sheet is 16ga and feels decidedly sturdy. I almost went 18ga and I’m glad I didn’t. Most bus bodies are 18ga. I’ve seen lots of raises with 18ga and the common theme I’ve observed is buckling and ripples after it’s moved around.
attachment.php
Sweet, thanks. The welder I'm looking at is a 210 amp, so if a 140 was able to do the job a 210 should handle it easily.
The way to use the thinner metal without buckling and rippling would be to groove it with a bead roller. Run a few beads down it, and it's quite a bit more rigid. You don't have to use straight lines either, you can put a little design flair into it if you like.
Thanks. I was looking at a 210 amp welder, so if you were able to do it with a 140 then I should be good.
The way to use thinner metal is to use a bead roller to groove it first. 3D shape is stronger. Here's 20ga from the factory on a bus wall.
This is 20ga sidewall on a bus from the factory.
[img]https://www.macallistertransportation.com/files/all-american-fe-exterior.jpg[/img]
