KlingonFiero
Hi all!
I’m picking up a new generator hopefully tomorrow.
It’s a fairly standard type open frame 3500 running watts, dual fuel (gas/propane)
I’m going to try to install it in the Engine compartment of my 40’ RE Thomas.
There seems to be plenty of room in the rear drivers side corner under the electrical box and next to the air filter housing.
Anyone else done this?
Good idea? Bad idea?
I’m also thinking of plumbing my propane to it as well, but have been unable to verify what pressure it needs???
I have a onboard ASME tank that feeds my water heater and stove/oven. Is that the right pressure already?
Or do I need to put in a Tee before the regulator and use the regulator that is supposedly coming with the generator?
Thanks All!
Thanks All!
