eggman-SKO
Looking at mounting the generator under the bus in a cage type frame. Current plans are to weld/bolt uprights forward, inboard, and aft of the generator and use bolts on the lower supporting frame work to facilitate easier removal for possible repair. The way I have it figured all frame work should be 1" square x 1/8" wall tubing. Along with 2" of insulating foam board and 1/2" or 3/4" plywood backing it along the 1" x 1" tubing.
Does this souund like it will work?
The generator is an older early 70's model 4K Onan. Weight is HEAVY!! My guess is around 175 to 200#.
Go Figure. I had the top rack and the bottom welded, was getting ready to weld them together and set the genny in. Oh well. That'll teach me to look at the wire before I start a large project.
I have a body lift as well . It;s a 3 inch Performance Accesories lift that I could get cheaper than hocket pucks. I needed it back when I had IFS o clear my 34's. Now I still have it even with the solid axle swap to get me some better firewall clearance. Even with my front axle pulled forward, with the amount of wheel travel I have, the close proximity of the firewall on Toyota trucks makes it an issue at full stuff with the wheels turned. Being 6'5" I can't afford to modify the firewall for clearance like some guys do. Not if I want to fit my left leg in the truck anyway.
