elliot_peas
Y'all I've been popping out windows and scraping caulk and replacing with butyl tape and I finally got some of that Dynatron Seam Sealer from the auto parts store. STILL GOT A LEAKY WINDOW CORNER. (Bluebird tc2000, 1998 )
I've had the subfloor down for a few weeks as a test fit and to see how it would handle leaks- attached is a picture of a few minutes ago, I've pulled up the plywood and foam board (using mdf 4" "struts"). Also a picture of one of the leaky window corners.
Only had a couple tablespoons of water under the foamboard and it evaporated quick once I pulled the boards up, but it has just been sitting there being wet and the Rust-Oleum is a bit rusty there now so I can't just leave it like this.
Ok so I'm gonna get in there where I've cut the walls out and seam sealer in around the lip that the window sits on. Today I seam sealered the outer lower window edge, there had been silicon v there.When it rains I really can't see where the water comes in, it's an extremely slow leak. Usually the ribs aren't damp, there's just a tiny little drip along the underside lip of the chair rail.
Do I just have to live with this? How do I keep it from eating the metal floor? I've really want to get the floor and and put the walls up and move on with my life.
