I love you guys bus!! I look forward to the seeing the transformation. I drove those kinds of Gilligs back in college and I love the way they drove! Good luck with the conversion and enjoy your videos!!
Thank you! Wow it is a lot of work to research every small step, constantly be learning to build a reasonable idea of how to execute the big picture of a school bus conversion, AND make videos!! Not to mention all of the other things we've packed into our lives lately (like a newborn baby, she's the best though). By the way you can see lots of photos at:
http://instagram.com/gilliganphantom
I can't say I've ever seen one. Not sure I've ever seen even pics. Thought they were more like Crowns.
Your bus, ... she has ... a nice personality? Lol. Too square and utilitarian looking for me. But congrats. It's obviously what you wanted since they are rare and 2600 miles away.
2603 in 77 hrs. I guess the Cannon Ball Run record is safe for awhile.
It's either what I wanted, or I'm a complete idiot (the answer is both). But really I wanted unique, and so I went out and got it (and now I'm trying not to destroy it). As far as I know we have the only one on the East Coast.
BTW you can learn all about this bus here:
https://en.wikipedia.org/wiki/Gillig_Phantom_(school_bus)
New video hopefully getting finished tomorrow.
Progress in the meantime includes grinding and priming the interior where I've pulled off paint by removing paneling and adhesive. Also thoroughly assessed windows for leaks and determined removal and resealing is absolutely necessary.
These buses have a drip rail that covers the tops of the windows that from my experience notoriously fails. When I removed it I found some silicone repairs (which may have made things worse), plenty of rust, and some missing window screws. I pulled the bump rail at the base of the windows to expose the bottom screws. When I removed each window Some windows kept all of their sealant (I think it's silicone based?? It's rubbery, and black), some left it on the bus ribs, and some pulled off paint on the bus ribs down to bare metal. All windows came out very easily. All seals were in some state of failure. So now every window is out on the passenger's side.
Next I scraped off adhesive left on windows, and adhesive left on the bus. I removed what remained with a wire wheel. In some areas I chipped away paint from the bus ribs and the top (underneath the drip rail).
I didn't expect to be repainting these areas and ended up doing so a little hastily with what was available to me at Lowes seeing as I've got to get these windows back in before leaving to see family in 4 days. I scuffed all painted areas with 220 grit sandpaper and then cleaned with soap and water per instructions on can of primer. I primed all rusted (after converting with ospho) and clean bare metal with Rustoluem Rusty Metal Primer:
https://www.amazon.com/Rust-Oleum-7...&sr=8-2&keywords=rustoleum+rusty+metal+primer this may have been a mistake as I've read about adhesion problems with this product when applied to clean bare metal and painted metal. My only recourse at this moment is to give it as much time as I can to cure (likely 72 hours), and I actually scraped some of it off of the painted areas. I worry that I've made a mistake but my goals are as follows: protect from future water and rust, and allow windows to reseal. I did not topcoat this product, and I'm not sure if it fully seals without a topcoat. I could not figure out if this product needed to be topcoated. Do you happen to know? Nothing painted with this primer will be visible in the end. If nobody here talks me out of it, I'll be putting windows back up without topcoating (but experts please chime in).
For the windows: I bought butyl tape:
https://www.amazon.com/gp/product/B00FI5ZW28/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1 it is 3/4 wide and 1/8 thick.
It fits my window channels perfectly and I plan to apply it to the tops and sides (the windows were not sealed at the bottom) and then screw them back in.
I also bought Sikaflex 221:
https://www.amazon.com/gp/product/B00NW5LWHA/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
I don't currently plan to use this on the windows, but it will be my backup if they leak after installed with butyl tape. I'll plan to run a super thin bead along the sides and top from the exterior. I'll also be using it when reinstalling the drip rail.
Thank you for following along and let me know if you can help about the primer, and if you have any thoughts about my plan to reseal windows positive or negative.
