A heat gun that is sometimes sold with a scraper blade for 20-30$ will allow you to work as you go to get the glue to let go.
More like a heavy duty hair dryer but it will help a lot verses chicken lamps.
Good call. I went for my heat gun first! Surprisingly the lamp was more effective.
I've been thinking long and hard about my exterior and how the roof with it's current access holes contributes to the environment inside the bus. Here are my goals:
1. Ventilation (both passive and with a fan)
2. Emergency Exit (mostly for roof access, nice but not crucial)
3. Skylight (would really like a couple)
I also want to cut minimal holes in the roof (ideally none), and seeing as I have two large emergency exits why can't those three needs (or maybe two) be combined into one already existing hole? If there were fantastic fans that fit a 24 1/2 x 24 1/2 cutout this would be an easy decision (why does that not exist?) Yes I know I can sheet metal over the hole and install a smaller one, but that is work I would avoid if I could. I could also do what
The Voyager Project did on youtube (
) for little money but then I won't get the skylights.
Here's my solution, I haven't seen it done before, let me know if you think it's ridiculous (mostly because of the expense):
I could install 2 really expensive boat hatches that fit my cutout size in place of the emergency exits and since my roof is flatter than most school buses I think I could do this with minimal consequence or fabrication. I could then have my skylight, roof access, and I could hang a box fan up there like in that video above and move a lot of air. I've found these hatches made for boats ranging from $215 (made in China) to $900 (made in the UK). I've seen some in person made by Lewmar and they're extremely nice, heavy duty, with some really interesting hardware. Here's the one I'm leaning toward:
Boat Escape Hatches & Ventilation Hatches
But I've also sourced this one on Ali Baba for $215 not including shipping
Made In China Boat Hatch Marine Aluminum Round Deck Hatch - Buy Round Deck Hatch,Marine Aluminum Deck Hatch,Aluminum Deck Hatch Product on Alibaba.com
and this one:
This product is no longer available.
I've never ordered from Ali Baba before and am not sure quite how that works, so I'm leaning to the first option which looks like a great product.
Yes this is me throwing money at a problem in search of the perfect solution, but I think it's a good solution. The only other thing I can think of is if I can modify the current hatches to accommodate a large piece of plexiglass in the middle and once again use the box fans.
My questions are: how do you feel about this idea? Do you have a better solution? And lastly, are those fantastic fans really so amazing compared to the box fan option that I should strongly consider those instead? Thanks for your thoughts.
