hmmm, i will consider water. thats not a normal situation for me for sure. the tire carrier compartment is enclosed, with weep holes. so it could flood. but water has never been an issue before with the lead acid setup.
from scratch, the batteries would have been inside. when the bus was built, fancy lithium batteries werent heard of. so there was no space built for them.
thats was the issue i was having looking at the victron line.... most of it duplicates what i already have somewhere else. to put it all inside would be a pretty major remodel. to add it on is just attaching a couple of wires.
i got out early this morning to see my little solar project. last night the battery started at 70% this morning it was down to 51% and charging. as the sun gets higher in the sky, i can see the volts and amps creeping up.
wow, i wish i had done solar a while ago.... pretty slick!
