kidharris
thanks KH!
interesting read on bluetooth.
the victron bluetooth hits my phone a long ways away. sitting at my desk, inside the house, i can sign on to the charge controllers and see what they are doing. the battery bluetooth, i was, getting up from the desk and going to my door, and it would work. now with the battery box, i have to go outside to the bus almost before it reads the bluetooth. ~20' ish
well, now i,ve had 2 failed nights of testing.
the box is giving me about 10 degrees of protection. night 1 was 20 outside, battery temp got down to 31-32, but the heating pad didnt fire. night 2, the low temp was only about 30, and the battery sensor was at 42, and the pad didnt fire.
the heating pad sticker says its should turn on at 45, off at 70.
the heating pad hasnt turned on yet that i've seen.
i really dont want to dissasemble and pack a battery and heating pad to my freezer for testing, fingers crossed it gets cold enough to work and it works.
out in the desert we use thermo cubes hooked up to heat bulbs to keep our pumps from freezing. Turns On @ 35F off @ 45F, uses120v power, just be careful how/where you point the bulbs, it can get really hot. The light can also be used as a signal to let you know when it is on.
could also be used as a backup. You can find them @ most hardware stores or online
https://www.homedepot.com/p/15-Amp-...ically-Controlled-Double-Outlet-TC3/100210525
