cadillackid
OK im going to paint the roof on my 1978 Superior white.. since I dont have a good place to spray paint without causing issues.. im going to roll it..
of course there are those elastometric paints.. however i want to learn about rolling and using hardener thr correct way..
so im thinking rustoleum with hardener..
1. which type rustoleum to use with hardener? (theres a zillion kinds)
2. what ratio of hardener to use?
3. best type / brand hardener to use
4. best roller type to use
paint prep wise im going to wash the roof with dawn liquid and hot water.. then go back over with TSP and water.. and then ill be palm sanding it with a 200 grit paper just to rough it up a bit and blowing the paint dust off with an air hose.
im starting with a roof because its the least visible.
id love to be able to use my airless sprayer but my storage unit has a ton of other vehicles in it so im well too close to other peoples stuff to blow spray paint.. even rattle canning is tough if there is any breeze.
