as you probaly noticed the trailer tails are disappearing. there was no fuel savings on them. when you talk of aerodynamics you can not use airplane design as we do not go fast enouh and with the trucks we found out they work but only when you are going straight into the wing . that seldom happens as roads curve. they do not work with any side wind. also the morons that forgot about them when backing up was friggn funny. air dams, a light foot and avoiding the flat fronts seem to be the way to go
I had through the traler tails and wheel covers actually worked but that there issues with them getting damaged by ill backing attempts then parts of them flying off on the road after damage..
my biggest thing to increase MPG is slow down.. sure I built a bus that frankly hauls ass but driving it at those speeds the MPG's goes down real quick.. running 65 nets a good mix of MPG and still making miles.. my preference in the vintage busses is to run 55-60 which nets great fuel Mileage.. smetimes less mileage.. as when you drop the speed smetimes a better route to drive is off of the freeway.. but of course you increase your time factor..
I personally dont drive the bus when im in a hurry.. I recently ran a rather fats road trip to get some A/C equipment that was needed fast.. I wouldve preferred to drive a bus because its more fun.. but the HEMI got the job because quickness was of essence in this case (A/C equipment in july)...
its a trade off.. a trade off that every hot-rodder has known for decades..
More speed == More Spendy. the same is true for busses.. you can make em go fast and do what you can to reduce drag (like not raising roofs and mounting solar panels or roof decks, etc...) but of course you lose features you may want / need...
another factor that few ever pay attention to are weather patterns on the days you travel.. head winds / tail winds / cross winds are a much bigger factor in your MPG than you may think..
for instance.. Beating a cold front with a leading low pressure system by heading northbound or east bound.. has a lot of precedence for getting a good tail wind. Low pressure systems spin counterclockwise.. staying ahead of one moving east / northeast by travelling ahead of it by a few hundred miles your MPG will go up..
trying to Beat a cold front by "getting out of dodge".. "holy crap snow strm is coming im heading to florida".. yeah you'll be running in a head wind headed south...
mountain areas are often subject to heavy winds on certain days and not others... you can watch the general patterns and pick your days to be in motion..
many times winds of all times will drop off overnight unless there is a weather pattern change coming (storm system marching)..
use the Big Box effect to your advantage when you can
