Are there any automotive A/C gurus out there? I just assembled the main A/C on my 2001 E450 shuttle and it's not functioning properly with a recharge.
I had removed the aux/rear a/c blower/evap/condenser/fans/hoses. It had been Tee'd into the front hoses with special aluminum tubes. I Didn't flush the front evap, compressor or hoses. I installed a new front condenser, accumulator, orifice tube, low pressure switch. Vacuumed system(held vac for 30 minutes), added oil, added approx 44oz 134A. Compressor clutch kicks on at 44ps and spins for 10-15 seconds. Low pressure drops very quickly from 44psi to 25psi. Compressor shuts off. Low side pressure rises VERY slowly (2-4 minutes) back to 44. Then repeats. High side goes up from 150 to 200 ps when compressor runs. It is 80 deg out. No cold or sweating A/C hoses. No cool or cold interior air. A/C sticker underhood says that system without rear a/c holds 2lbs, 12oz. That's what I was trying for.
Any ideas for me. Thanks.
