jfmusic@me.com
Apparently, DRL is Daylight Running Lights. Who knew?
And there is a DRL ENG SIG. path that I'm not sure how to test?
DRL ENG SIG?
I supposed it could be with the engine running; the Audible alarm is canceled... feed.
Is there a master chart of the Pxx Connectors locations somewhere?
They are named but that doesn’t clue me into the location. "Body connector "could be anywhere...
And the colors as I have applied them are for separation only since I am partially color blind.
I am on the hunt for main feed to the DRLs
RE:Found the 4 Small Relays each associated with a portion of the DRL. In the side panel next to the driver's seat. I rotated them all in one position just to see if there would be a difference. And there was not.
Thanks in advance
DRL ENG SIG?
Thanks in advance
