jazty
if all of your coolant in the heater loops is cold you will in fact instamtly drop your engine temp when you open that valve because you start pumpimg 80 degree coolant into a 200+ degree loop... so yeah it will definitely drop it...
no doubt the interior heaters help and may act as secondary radiators.. im a proponent of first making the factory gear work correctly.. over-heating your bus engine is no laughing matter...
Yes, I crack the valve and slowly open it over time to not shock the system. When the valve is fully opened and the fans are on it keeps things running nice and cool. It's not the preferred solution, but it sure beats overheating in a pinch.
I'll replace the fan clutch one of these days, but I still like the idea of an auxiliary rad. The fan should run less and it's a neat backup system for another fan failure. Anyone with a split-rad can appreciate an aux rad, I reckon.
