PorchDog
1996 Bluebird, DT466 Mech. Spicer 5 Spd. 6 window
It has to turn 100 RPM to start, and the glow plugs MUST work. These have Ricardo Comet precombustion chambers, so the injectors spray into these chambers and not directly into the combustion chamber like a Cummins. To my recollection, these used a glow plug controller that screwed into the water jacket at the back of the engine or intake manifold. It has a large round plug that connected to it. These would go bad, some times they would work when very cold, and not when luke warm, or maybe fail altogether. Folks would try to work around the controller (because it was expensive) and install push button switches to manually control the glow plugs, and that usually resulted in burned out glow plugs.
With good batteries and properly functioning glow plugs it should start fairly easily. This is all from what "I think" I remember.
And I may be mixing 6.2 stuff with 6.5.
You can absolutely fry a starter, and ruin batteries with no glow plugs.
