Thank you for the estimate! I'll be working to try and beat that estimate, but it won't put us in a bad position if it takes 2 years. It's good to know what a 'worser' case (but not worst case) might look like so that I can confirm that doesn't put us in a bind anywhere.Two years.
I've come into this assuming I would need to pick up a bunch of new skills. I'm expecting that to be challenging, and frustrating. Ultimately a lot of those skills are things I'm going to need to learn in order to build a house later on, so at least I'll be able to leverage the skills across more than one project.You can learn the skills along the way, if you are open to learning the skills.
We've got the money in savings, so this shouldn't be a factor that slows us down.If you are building using cash flow, that may further slow the schedule depending on how hard you are willing to squeeze your budget.
Thank you for the callout on the maintenance and repairs! If you had to put a number on maintenance for something that is only being driven ~500 miles a year (~10 miles each week to recharge fresh water, top off the tanks, and discharge gray water), what would that look like?Yes-a big one, and a bigger one: bus maintenance, which is required whether you drive or not; and bus repairs, which can be incredibly costly.
Bus maintenance includes oil, filter and fluid changes on a periodic maintenance schedule, and build maintenance such as storage battery replacement and other conversion costs that will accrue even if the bus never moves.
Obviously that is going to vary from bus to bus, but I'm just hoping to get a ballpark number. <$1k per year?
This is also a great callout. Thank you. This is again something that I would expect to vary greatly across buses and use cases. Do you have a sense of what that might look like on average and worst case for people who don't do much driving?If your dream includes taking road trips, getting the bus in good mechanical shape is essential to avoid the stress of unexpected breakdowns. keeping the bus in good mechanical shape will require, over time, that you invest in bolt-on replacements (alternators, starters etc). Some of this is dependent on usage; all of it is dependent on the mechanical condition of the bus when you take ownership and park it in your driveway on the first day.
Something like the average bus seems to need 10k in the first 3 years and the worst case is more like 25k in the first 3 years?
My main concern here is that the incremental costs to being in a bus over the course of 3-4 years are more likely than not to be less than the 24k per year I'm currently spending on rent.
We've got a cash cushion, so it's not problematic if we have a bad year or two if the average over the years is highly likely to be less than what we are saving in rent.
I did have a generator in the plan, but I hadn't considered the maintenance aspect there. Thank you for flagging!You'll also pretty much need a generator (which has it's own maintenance and ongoing costs) for power on a periodic basis, unless you have shore power. If you take the bus on trips, even with solar you'll need something to keep the lights on.
Thanks, Rucker--I really appreciate that!I'm really glad you came to this forum and are asking all the right questions. We all want to see folks successful, and the biggest factor in bus conversion success is starting out with open eyes (which only come with an open attitude like yours!) . Good on you!
I considered an RV trailer and did a little bit of research there. For something without a motor, I was seeing prices that were 30k+ for 30-foot trailers.PS. Have you given thought to an RV trailer instead of a (more expensive on every level) bus? Finding one big enough might be challenging, but it would be an excellent proof of concept for the family.
The space was less customized for our needs, and we'd still need something to tow it with--especially given that the water tanks generally seemed to be small and therefore we'd be making frequent trips to fill up water until we hit the point where we had a well. Not only that, the general sentiment I was seeing online seemed to indicate that the build quality/durability for a lot of the RVs was questionable.
It seemed to me like we'd get a better bang for our buck (albeit with a huge investment of time), with space more tailored for our needs and a better, more durable build by going with a skoolie.
I'm happy to have you flag though if there are aspects of the situation that I'm overlooking though!
