Hello! New To Skoolies & The Forum!
geminusprime
Dec 27, 2018
255
Rock Hill, SC
Howdy folks, I'm Art. I hope the year treated you well, it's certainly been a wild ride for me.
I've been lurking on these forums for quite a long time, and decided it's finally to take my dream and make it into a reality. I've always wanted to travel around the US, specifically to all the National Parks, but never had the time or money until recently.
I hope I'm on the right track, as I'm looking to buy a bus in the following weeks, but any advise or input is welcomed. I honestly have no real clue what I'm doing but so far this community has been astoundingly helpful from its existing posts.
So here's my current standing:
Initially I thought the TC1000 platform was my preferred option, and did a fair amount of floorplan variations for it. However, I did not notice the incredibly small wheels, which I doubted would be able to get me over unpaved roads that's seen in some of the more remote national park and national land areas. It's also more rare, and I'd likely not be able to find one locally.
I do want the bus to be able to drive in mild offroad areas (that a sedan could go to) and be capable of driving over even terrain in snow/rain. This is pushing me more to the direction of conventional dog-noses which has a better approach angle & clearance, but please convince me otherwise - I love transit styles.
Right now, I've decided to go with a 1995 International 3800 Conventional, ~30'. Fairly sure I'm going with NC School System, their website is horrible but they have some good deals, $2750 to $4500 for most of their buses. I'm sticking with the midlands area, away from the mountains and coastal areas, looking to be either Union or Mecklenburg counties.
Engine in most is the DT444E, I've only found a couple so far with the DT466 (that weren't the 3800). Plenty of Cat's & MBD's, which I've ruled out as options. Cummins are kind of my last choice that's acceptable, but I've read enough to narrow down nearly all searches to the DT444/DT466+545.
I would very much prefer a mechanical DT466, but after reading many users here that run on the DT444E platform I think I'd be okay with the electronic version of the DT466 or the DT444. I know this comes at reduced HP and somewhat lower speed with the 545 and 4.44 back end, but I am comfortable rocking 60MPH max down the highway in a massive piece of speeding steel.
As for the length, I simply am not comfortable with a whale tail in cities, enough that I'd be okay sacrificing ~10 feet in lieu of a smaller vehicle, shorter conversion schedule, and better turning abilities. At maximum capacity, it will be two people and a dog on 1000+ mile trips, and 4 people + dog for <=250 mile day trips.
I also have a need to be able to park within two lateral parking spaces for normal vehicles, such as long ways in a walmart parking lot. Both for general parking, and because the area I'll be doing the build is 32' (with that leaving 2' at the front/back of the bus).
Hello and welcome. I would start looking at maybe shuttle bus's and van based bus. If you not going to be living in it full time and want just an RV, I would do that. If you're going full time living in it then yes maximize space.
Hello from the carolina's.
Started a response on one of your other threads but timed out cause of other work.
Are you talking of union point NC as far as looking for a bus?
I have a onslow county spec bus that was well maintained with all records since the build sheet day handed over.
PM and I can help you find what you want.
I am looking for a donor to help re-power what I have now.
Good luck
Welcome!
The T444E is very well respected motor. I would not hesitate to buy one.
But...... I would not even consider trading my Cummins for one. :)
You may want to call and verify the rear end ratio. I ran into one from NC that had 6.17 rear gears and had a top speed of around 53 mph.
Good luck with your quest.
Welcome aboard! I love my T444E and AT545 combo. I just finished a couple long Interstate drives and it cruised along at 60 MPH for hours on end and ran like a champ as it always does.
Ah, yeah I left out a bit about the travels. While some trips may be a weekend trip, others I'm trying to push over the course of several months, and at least one venture to Alaska (although air brakes may cause me issues here).
Good luck
Union County, near Charlotte, but that's just because I'm living in York, SC right now and that's just north of me, but I'm open to pretty much the whole NC state other than coastal areas and mountain areas.
I'd be more than happy to reach out, although not sure what onslow means. I'll shot you a PM a bit later.
Welcome!
Thanks! I've only found a select few in the NC system that don't have higher rear end gearing, only found a couple so far that they could confirm was a 4.44 activity buses.
GReat to hear man, I've honestly been worried that a few backup buses I'm eyeing have the 444/545 and wasn't sure about the top speed (assuming rear ratio is low enough). 60MPH will make me more than happy!
Also amazing build and inspiration, I'm likely going to wind up with a similar/same bus and engine combo as yourself.
The mountain busses are the ones that are already set up for driving in the hilly areas.
Heavier duty brakes.
Bigger radiator.
Bigger transmission cooler. At a minimum.
Maybe sanders for traction on slippery roads.
Engine braking and other extras you won't find from the mild to coastal area districts.
Rust in any bus regardless of district is always an issue. My coastal bus all its life had very little rust issues.
Only rust I found was under the rubber flooring from the windows leaking.
and maybe the maintenance department pressure washing the bus out?
but it was only surface rust.
Onslow is the county I live in on the coast.
The counties I mentioned. Wake and mecklenburg are an hour or so south of Charlotte on i85/40. But a hilly area and very large districts.
Good luck
Welcome to the site! We bought our bus from Moyock, NC but it was actually a Chesapeake City School Dist bus. When the dealer inspected it up here in NH, he said it was one of cleanest buses he has seen. He specifically made the comment that even the oil pan didn't have any rust on it. We held out for the DT466(E) with an Allison 2000. Yes, there were lots of T444s with the 545 that we passed on, but the one we were looking for finally did show up!
466E/2000 is an excellent combo. I've got that combo in my 6 window.
I now have a 5 window with Cat3126 and 545. Bus has 64k original miles and is on its second 545. The transmission sucks but its 100% functioning for now so I'll spend a few grand to upgrade it later on since the engine/bus has such low mileage.
I had a 444E/545 bus and always found myself wanting for more.
