I'm curious about this myself. From reading the conversion threads, here's what I've gathered so far, please correct me if I have something wrong, or missed some important steps:
- Remove the seats
- Double check your plan. Maybe tape out the floorplan to make sure everything fits the way you think it will. Figure out where tanks and such are going to go.
- Generally, take down the interior ceiling panels, the interior side panels (walls next to the seats), and pull up the rubber flooring and plywood underneath
- Remove the nasty, moldy insulation (some people get lucky and don't need to demo quite so much, but it seems like most do. Either we're an ambitious, overachieving bunch, or it really does make that much of a difference to replace the insulation. Probably a little of A, a little of
- Kill any rust you find. Sand, blast?, weld on new sheet metal if the rust has actually eaten through, paint on some rust converter to prevent further deterioration, prime with some sort of rust protecting paint.
- If you need to add bays underneath to hold your tanks and batteries and whatnot, it's probably reasonable to do this while you have the floor down to bare metal.
- If you did a roof raise, or plan to cover some windows, or otherwise modified the skeleton of the bus, then attach additional sheet metal to "skin" the exterior. If you took windows out to raise the roof but want to reuse them, you may also want to reinstall those, and reseal them with caulk.
- Add in studs (maybe optional? but it seems like several folks use a jig to drill some pockets into wooden studs then attach these to the steel ribs of the bus)
- Insulate as desired. Lots of folks use foam sheets. Some use wool or cotton? Some use spray on foam. Some use stuff that looks like bubble wrap. Some use foil backed insulation. Some use house wrap (tyvek) for a vapor barrier. I have no idea what works the best.
- Lay down some plywood to use as a sub floor (does this get screwed in, or does it just sit on top of the insulation? I hear people saying they don't want any holes in the bottom of their bus, and that seems like good sense!)
- When do we install seatbelts? I thought I read that they get anchored through the floor? Do you install them before you even have seats?
- Walls? Ceiling? I think this seems to be the point where people usually start covering the interior back up.
- Paint the exterior of the bus. This could maybe come later, but if you plan on putting solar panels or a deck on the roof, you probably want to do it sooner rather than later.
- Install windows (if you're using RV windows, this seems to be when they get installed so that they fit the full thickness of the insulated walls)
- Start framing out the interior. Any partitions, built in furniture, etc.
- At SOME point, I assume the electrical and plumbing (such as it is) need to be handled. This could be before you start covering everything up? Or maybe after you've at least roughed in where everything is going to go?
- Probably test all that before you get too crazy with interior decoration. I'd hate to have to rip apart something that was already "finished" to troubleshoot issues.
- Install lighting, vents, heat, a/c, shower, sink, etc. (this all kind of goes with the wiring and plumbing)
- Paint/stain/etc. the interior now that you have walls and partitions up.
- Finish up any built ins, things should be pretty functional by now.
- Lay the flooring
- Add textiles and upholstery
- Do any finishing, trimming, etc.
- Move in your personal belongings
- Celebrate!
Do I have the right general idea?
