slipperysam
- Joined
- Aug 25, 2020
- Posts
- 23
Hi all,
I have a 2000 BlueBird CSRE. I've been living in it for a while now with the original door. The way the door operates is an on/off switch on the driver dashboard to hold it open or closed. The switch only has on and off states (it is _not_ one of those momentary electric switches). We use the switch to open and close while we're inside the bus, and when we leave the bus, we put the switch in the closed position and pop the emergency switch so that the door opens and closes manually. Then we just pad lock the outside when we leave.
I'd like to install some relays so that I can control the door programmatically. I have inspected the switch and the door itself, but unfortunately since my bus is already complete, I can't really trace back all of the wiring without ripping out my ceiling. So, I was hoping someone more familiar with this can help me piece together how it works.
Here's a picture above the door:
and a diagram drawing out that system a bit clearer (including the results of some multimeter continuity tests on those solenoids):
There are wires that go down to the light, but the light only turns on when the door is open and the keyed power is on, whereas the door itself works regardless of power being on/off.
For completeness, here are pictures of the switch being open, closed, and the back of the switch (its the golden box thing):
Also relevant perhaps: when you use the switch, you can hear some air pressure being released at the switch site.
So, with all that in mind, I hypothesize that those black and red tubes are _air_ and not electricity, and the door switch is directly sending the air to either the door open (X) vs closed (Y). Which would be unfortunate for me. Initially, I thought that the two circular items above the door were solenoids that directed the air depending on the electricity supplied to the four terminals, in which case I could just figure out what power to supply when and be done with it. Does anyone know what those things are and how they work?
Thanks for any help!
