HELP! new bus owners stressing over here
bakedbeans
Nov 21, 2024
4
hey everyone! complete noobie here so hello hello
we just got this 2003 ford e350 super duty short bus and are in dire need of some help.
there is a ton of rust and few cracks in the frame that supports the floor that we need to sort out but are unsure of how to fix them(we also do not know what they are called). the actual body seems to be in okay condition, it is just under the floor that seems pretty bad. i will attach a photo. any help on literally anything is VERY welcomed!!!!!
Looks in tact. I wouldn't worry too much. A wire brush could be used meticulously on them to remove all the lose rust, then spray a self etching primer and then oil based enamel paint after that to protect it later.
I took some screen shots of a video i took that shows more of the damage underneath! ill make a new thread
You have so many threads going... The other thread that beam was gone... Only thing you can do is cut it out, and replace with a piece of box tubing the same size. If it is more then one you may want to think is it worth it. Is it gas or diesel? if gas be very careful about sparks from cutting the beams.
Buyer Beware rather than Buyer's Remorse
My response is not so much to the OP, because without a lot more information and detailed pics of all the rust, none of us can give them a really helpful response. From the one picture, it looks like it's not too bad, but it could be terminal.
Newbies, before you buy a bus, take a hard look at it. You don't accidentally get saddled with a rust bucket. Most school busses are a chassis bolted onto an open frame.
Put on a pair of coveralls, put fresh batteries in your flash light, grab your chipping hammer and crawl all over that rig. Whack anything that looks suspicious with the chipping hammer and see what falls off.
Do a deep dive through the threads here and see how much work many have done on rust remediation. I am old and tired so my attitude is that any significant rust means, "run away!" Others would say, "if the price is right, there is an acceptable amount of rust that is worth doing the work to get rid of it.
Growing up in the rust belt, SW NY and PA, and being a licensed PA auto safety inspection mechanic, the common term for rust in a car or truck was, "body cancer." You might go into remission with enough treatment, but the likelihood is that it will return.
There are a lot of challenges that, when they pile up, often lead to enthusiasts burning out before they get to the really fun part, living in your creation.
If you have been lurking, waiting for the opportunity to, "pull the trigger," on your first bus project, take a lesson from the contributors here who have shared their challenges and solutions to common problems that often come with a used school bus, make a list of problems you want to avoid and be patient in the purchase processes and wait for the right deal.
Things that may say, "Walk Away:"
  • Severe Rust in the frame or Chassis
  • Severe engine or transmission leaks
  • Corrosion in the wiring harness
  • Bad engine sounds
  • Slipping or not shifting transmission
  • Overheating or history of overheating. (I have seen busses for sale that the seller says they just replaced the water pump, thermostat and flushed the radiator. Later revealing they were trying to solve an overheating problem. You have no idea how badly they overheated and how much damage was done.)
  • Whining or clunking from the differential.
This is not a comprehensive list and I am sure other folks will add on to it. My point is this: Building a skoolie is an adventure. Adventures are a lot more fun when you start with a sound foundation. You are unlikely to find a completely challenge free bus. They are big machines that have been worked hard for fifteen or twenty years, but pick your battles.
One thing that sinks a lot of beginners is the discovery that this is not an inexpensive sport. The more you can learn about maintaining and repairing your bus, the better off you will be.
A tiny bit off topic: Before you start deleting wires or hoses, do a deep dive into the end results in the many threads that start with, "Help, I may have screwed myself!"
Second Photo & Concurrence
  • Bad engine sounds
I read this post in its entirely & I agree with the entire post.
I'll just add this picture from the other thread (under-body-rust-help) so we might better see the extent of the cancer.
attachment.php
is this a body mount? Are there more like this?
attachment.php
Well if it were me I would have run
If somehow in a drunken stupor I bought that hot mess, I would be looking to part it out or find a buyer who was looking for the running gear. I would never be interested in taking on the incredible restoration project that would turn out to be.
In good conscience you could not pass it off on another buyer without disclosure.
I have had a few strokes, and live on supplemental oxygen. It might not take a drunken stupor for me to have a low pulse-ox, to much money in my pocket, Alzheimer's, moment to make that kind of mistake....heck who am I kidding, I buy my vehicles in the "no rust zone," for a reason. If somehow, (and I think the would have to be foul play for it to happen), I got stuck with that, I would cry like a little girl!
In light of these new pictures of the broken down frame, I retract my previous statement.
This can be repaired, but it takes a welding experience to do it right for strength. Requires detatching the back cab completely, and replacing the C Channel or Square tubing completely, and then reattaching the cab.
It's likely gonna be far more work than you'll want to do. If you feel like you can tackle it, then more power to you, but it's gonna be a ton of work to fix for a novice.
