Hello all,
I'm having issues with my circuit breaker box and am not sure what the problem is. I've got my solar panels hooked up, my inverter connected to the battery, and shore power goes to the inverter without any problem. The inverter is able to supply power from the battery bank without problem as well. The issue is when I have the ac output wires from the inverter connected to the circuit breaker box. When connected, the gfi at the outlet supplying the shore power trips. I've confirmed the voltage of the output wires is 120v. I have tried both of the red circled areas for the hot wire, and have attached the negative wire to the white circled lug. The top ground wire goes to one of the metal ribs on the side of the bus. The bottom ground wire is the one coming from the inverter. The main breaker is a 100 amp breaker and I chatted with the maker of the box when I was trouble shooting how to add a main breaker and they said that the box did not need a ground bar and negative side bars could be used for the ground. I appreciate any help you all can give.
