ntrain6942
- Joined
- Aug 3, 2016
- Posts
- 53
Hey folks..........tired of money wasted on rent so bout to buy a schoolbus (35' long 1997 GENESIS AMTRAN flat nosed FE w Dt466 motor w 150k)for $2200. Hoping you all can help a noob out......
Thanks! I was originally looking for a rear engine flatnose........but after seeing a FE setup......felt it makes more sense........more room in bedrooom which will be located in back with a rear door(plan to build porch around bus)and the bathroom n water tanks will be over the rear axle.......so the F n R weight distribution........that leaves living room n kitchen towards front. Yes the FE has a driveshaft........but after looking underneath storage still wont be an issue on a 35' bus.Hi there! :welcome:
You got a nice bus there! Folks here will help all they can...
Just picked her up and got her home. $2200. 35 foot 97 Amtran w dt466/at545 combo.....150k on odometer.........needs some body dent work n rust repair but i think for up here was a decent deal.......frame itself is super clean.......solid tires n air brakes.![]()
Here is a pic of it sitting in driveway...........errrrr, not, keeps saying a 653kb pic wont upload from my pc......
file failed?
file failed?
Thanks! I was originally looking for a rear engine flatnose........but after seeing a FE setup......felt it makes more sense........more room in bedrooom which will be located in back with a rear door(plan to build porch around bus)and the bathroom n water tanks will be over the rear axle.......so the F n R weight distribution........that leaves living room n kitchen towards front. Yes the FE has a driveshaft........but after looking underneath storage still wont be an issue on a 35' bus.![]()
